myredracer
Jun 14, 2016Explorer II
Also, by doing that you are setting yourself up for a possible voltage drop problem. The NEC only requires a demand factor of 3600 watts (30 amps) for a pedestal with 30 and 20 amps on it and the wiring to a pedestal is sized based on 3600 watts. Because of the way older CGs were wired they could be a voltage issue, but newer CGs are loop-fed and you'd likely be okay.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
