time2roll
Apr 13, 2018Nomad
To be independent you need more battery, not less. To get more from solar or from the dreaded generator consider a lithium battery. Going to be a bit extra up front but could be the last battery you buy.
Yes for a larger system going 24 or 48 volts will have an advantage. I assume you are thinking 800+ watts solar.
Yes you can get a DC/DC converter to power the 12v accessories. I recommend Victron.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
