2oldman
Apr 14, 2018Explorer II
furyous68 wrote:I'm not sure what you mean by efficient, but losses due to any perceived inefficiencies are tiny compared to your actual use.
It appears that swapping to a couple 24v batteries in parallel with a 24v-12v step-down converter between the batteries & the RV's converter is possible, but not the most efficient system.
furyous68 wrote:4-6v in series = 24v. No difference in ah.
running 4-6 deep-cycle 6v batteries in parallel/series seems to be the way to go. It would probably be a lot easier to set up, & give me way more amp hours in the long run?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
