Sam_Spade
Apr 14, 2018Explorer
theoldwizard1 wrote:
Achieving proper multi-step charging will be the BIGGEST problem to solve !
But not the only one.
This is NOT a project that should be undertaken by a novice.
The OP, and anybody else for that matter, should be able to build a very capable and reliable 12 V system using relatively inexpensive off the shelf parts. One BIG advantage to that is: When you build a "standard" system, then others will know how to test and fix it should the need arise. Including the next owner(s).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
