theoldwizard1's avatar
theoldwizard1
Explorer II
Aug 28, 2018
Use gray to flush black
Related to my previous post, has anyone tried some kind of pump to use their gray water to flush a toilet ?
  • Bobbo wrote:
    Gray water stinks as bad as black water. I wouldn't want that in my toilet after you flush.
    Grey water that includes kitchen waste does smell bad, but if you have two grey tanks the bathroom water is good quality and stays that way with the use of black tank chemicals and active use.
  • theoldwizard1 wrote:
    TakingThe5th wrote:
    I have a grey water flushing system installed in my 5th.
    I have a separate pump and filter for the grey side.
    Anything "special" about the pump and filter you are using ? Could you share the brand and model numbers ?
    The pump is an Artis Model PDS1RV25, 40 psi max, draws 7.0 amps on 12 volts.
    There was no visible information on the filter but it is shown below
    Here is the pump and filter. The water flow is up and over. The lower pipe taps into the grey water tank about one quarter up from the bottom. There is also a low point drain on the lower pipe which is needed for winterizing -
    Click For Full-Size Image.
    Here is a close shot of the filter. You can see the screen -
    Here are the valves used to select fresh or grey water for flushing. Grey feed is on the right, fresh feed is on the left. The blue pipes are the original fresh water supply. The valve on the right selects the water source. The valve on the left, along with the check valves, is used to insure that no grey water enters the fresh water system. Right now the valves are set for fresh water use -
    And finally, this switch powers the demand pump and is in the bathroom. Normally left on, but if the pump starts grinding in the middle of the night we can quickly stop the noise and save the pump. Originally I wanted to mount all the valves in the bathroom next to the toilet, but there was not enough room. -
    Hope this helps. Good luck -
  • BarneyS wrote:
    Vintage465 wrote:
    Before I got a trailer with a Sani-flush, I would drain the black tank first...leave the black tank valve open....Then......Carefully remove the end of the hose from the dump station hole and hold the hose up in the air, higher then the tank and reach down and open the grey valve. The grey water would run into the black tank 'til it equalized...tricky part was shutting both valves while you continue to hold the hose up. And there would be a little "mixed" waste water in the hose while you got it back to the dump station hole. I suppose you could install a third valve to manage that though.
    Just get a Valterra Twist On Gate Valve and put it on the end of the drain pipe just in front of the slinky. That way, you can close the valve, open both grey and black valves, and the liquid will equalize without going down the slinky. When done, close one of the tank valves, open the Valterra and drain as usual.
    It looks similar to this one but without the clear plastic elbow.
    Barney
    I always thought to myself why don’t they plumb the gray tanks to flush through the black tank to help clean it out. Then a while back I bought the twist on valve. OMG it works like a champ! I still use the sani-flush to keep clear water flowing into the black, but this is the way to go.
  • Almot's avatar
    Almot
    Explorer III
    mockturtle wrote:
    I think some of you guys are just bored. :R ;)
    x2.
    Emptying dish water in toilet is simple and efficient.
    For a while I kept my kitchen sink drain open, collecting water in a small bucket and then emptying on surrounding shrubs, they appreciate it on a hot day. Slight complication was that I couldn't see when the bucket was full until I open the sink cabinet, so I stopped doing it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
