theoldwizard1's avatar
theoldwizard1
Explorer II
Aug 28, 2018
Use gray to flush black
Related to my previous post, has anyone tried some kind of pump to use their gray water to flush a toilet ?
  • When our gray water tank starts to get full, we open the valve and drain some gray water into a bucket and then pour the bucket into the toilet. Both the gray and black tanks are 25 gallon, but we generate about 5 gallons of gray water a day and maybe one or two of black water. So this "bucket brigade" helps extend the time that we can boondock, and it also dilutes the black water.
    A pump would be very useful, but I am not sure how to plumb it safely.
  • Run the water that you waste to warm up the shower into a bucket and use that. I would use the gray water. I have a clear section of sewer pipe and the first glug of gray water is pretty nasty with solids and coffee grounds.
  • I would suggest that you find a flat pan and collect the shower water as you stand in the pan. Some might miss it's mark, but pour that into buckets, maybe through a strainer to collect the hair. There is small lines and valves that water has to flow through, and the use of gray water as a flusher could lead to a lot of problems if something that went into a gray tank gets stuck along it's path, or causes gate valve problems in the toilet.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
