Old-Biscuit
Nov 12, 2014Explorer III
The exhaust cools off within a very short distance......so installing piping will accomplish nothing as far as 'heating'.
It will cause back-pressure issues which will result in furnace shutting down.....resulting in NO heating.
Combustion side fan is designed to supply just enough air flow for proper combustion (fuel/air ratio). Disrupt that and no heating...problems with ignition, problems with maintaining main flame, problems with excessive heat within exchanger---high temp trip.
NO it won't work.
'4 Season' rig.....
Fill fresh water tank-use pump>>>>>>>disconnect water hose and stow (use during daytime to top off tank)
Shop light in take area......GOOD!
Ice maker line blocked off......Good!
We spent 2 weeks in temps that didn't get above 0*F and went as low as -14*F.
Propane, propane,propane......run that furnace
and open cabinet doors at night so heat can get to areas under cabinets where water lines run
NO it won't work.
'4 Season' rig.....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
