rvtwerner's avatar
rvtwerner
Propane tank inside or outside of RV?
I'm taking my class C (27') up to the mountains this weekend where there will be no electrical hookups. I'm using my recently purchased Camco Wave 6 cat heater. On previous trips, I cracked a window and ran the propane hose outside to a 20 lb propane tank. But recently, started having problems with regulator freezing on the tank that I suspect was cutting off gas to the Wave 6 heater.
Can you all remind me what the risks are of keeping the tank inside the RV? Is it a gas leak issue, explosive issue? I've seen some folks build a small compartment for the propane tank and keep it inside.
Thanks all!
