Elk_traveler
Mar 19, 2021Explorer
I purchased and use the portable buddy which uses the 1 lb cylinder propane inside the RV. Works well except the little tanks last only about 4 hours on low. The portable buddy is made to be use in the inside with of course a vent open to allow fresh air. If using outside you can connect to a regular 20 lb tank. The little heater works quites well.
38,782 PostsLatest Activity: Sep 10, 2026
