rambleonrose's avatar
rambleonrose
Explorer II
Mar 24, 2019
Vinyl flooring - plank or sheet??
Hey folks
As soon as the weather cooperates and we can seal the roof, a new floor goes in!
We're wanting to go the vinyl route, but with all the research I've done, I can't find enough info on what's better for an RV - vinyl stick planks, or the more traditional sheet.
I have seen a few pics here where the sheet split - I'm in upstate NY, so weather is a big factor to my decision.
But.... how's that vinyl plank for moisture control? Was leaning towards sheet because there are no gaps, but I shudder at the notion of all the work and then a crack after the first winter! I like the idea of the plank/tile installation, as it seems way more familiar to me, having done floating wood floor and the like, but I'm worried with the temp expansion/contractions the gaps will be bigger, and any spills can wreak more havoc.
Also, regardless of type, going on top of particle board sub floor, is there a moisture barrier to put down as well?
Any tips or tricks on either of these would be extremely helpful for our decision!
TIA!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
