kaydeejay's avatar
kaydeejay
Question on replacing vinyl sheet flooring
Looks like a combination of old age and this Winter's severe temperature was too much for the vinyl flooring in my fiver - it ripped/cracked from one side to the other.
Must have shrunk first as 1/4" was pulled out from under the floor heat register.
My question - can I replace this with "Peel & Stick" tiles?
I have removed all the vinyl and the plywood underneath is smooth, clean and dry. But when I look at the instructions on a box of Armstrong tiles it tells me the temperature should never be allowed to fall below 55 degrees once the tiles are installed.
What is the downside? Will they shrink, peel off or what?
Has anyone else done this?
Any insight would be appreciated.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
