rambleonrose's avatar
rambleonrose
Explorer II
Mar 24, 2019
Vinyl flooring - plank or sheet??
Hey folks
As soon as the weather cooperates and we can seal the roof, a new floor goes in!
We're wanting to go the vinyl route, but with all the research I've done, I can't find enough info on what's better for an RV - vinyl stick planks, or the more traditional sheet.
I have seen a few pics here where the sheet split - I'm in upstate NY, so weather is a big factor to my decision.
But.... how's that vinyl plank for moisture control? Was leaning towards sheet because there are no gaps, but I shudder at the notion of all the work and then a crack after the first winter! I like the idea of the plank/tile installation, as it seems way more familiar to me, having done floating wood floor and the like, but I'm worried with the temp expansion/contractions the gaps will be bigger, and any spills can wreak more havoc.
Also, regardless of type, going on top of particle board sub floor, is there a moisture barrier to put down as well?
Any tips or tricks on either of these would be extremely helpful for our decision!
TIA!
  • Check with your manufacturer and see what they suggest. It's all well and dandy getting advice but if the dealer doesn't use it the there is a reason.
  • plank flooring will generally be much heavier than vinyl. So make sure you have enough extra CCC to accomidate the extra weight.
    plank will be easier to install
    There are places near me who do trailer vinyl install. not inexpensive by any means. they make a heavy paper template of the trailer after they cut out the exisiting vinyl the use the template for the new vinyl. Fitting under the slides is tricky. And sometimes they can't do it without at least one seam somewhere.
  • Cummins12V98 wrote:
    The LVT is glued to a plywood substrate, NO gapping is required.
    When you say LVT is glued to a plywood substrate, was that how it came, as in pieces that snap? Or were you the one doing the gluing? I think I'm confused because many things I read are interchanging the terms LVT and LVP, but there's a significant difference in function/installation, as well as price.
    According to Lowes and a few other articles I've read, it's a self stick piece, just like the more cheapo vinyl squares - peel the back and stick on floor, and done. Then I have also read about LVP, luxury vinyl PLANK, which is manufactured just like locking hardwood, with grooves that snap, and results in a floating floor. Many suggestions here and elsewhere say the plank is the way to go, but then also refer to it as LVT, which is apparently totally different.
    I'm just trying to figure out what to buy, and how much to budget - the tile is obviously cheaper, but for some reason I can't seem to figure out if folks here are talking about the peel and stick vinyl, or the floating snap together vinyl.
    Any clarification would be super helpful!
    Old Rosie is a ratchet old beast from '86 that I can't even find a user manual for online.
    (PS if anyone knows where I can get my hands on a Chevy Crossman by Esquire manual, let me know!!! haha! No really, it's been a time figuring out this old stuff... :/ )
  • NO snap together stuff! LVT is "Luxury Vinyl Tile". It needs to be glued down. It is a heavy duty tile that is at least 1/8" thick. NOT cheap!
    Pic above is mine at the Factory, it has square edges that are butted together and glued.
    Thanks for the clarification! I've done the groove/snap installation before, with wood flooring. Not hard, but a pain. Tiles sound easier.
    Just like the glued tile, the LVP comes in many varieties. The tongue and groove LVP I just installed is quite thick and rigid. At 2.25 lbs./sq ft, it is substantial. And believe me, it is by no means cheap!
  • Simply try to replace one of your damaged snap/lock tiles when it's damaged.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
