rambleonrose's avatar
rambleonrose
Explorer II
Mar 24, 2019
Vinyl flooring - plank or sheet??
Hey folks
As soon as the weather cooperates and we can seal the roof, a new floor goes in!
We're wanting to go the vinyl route, but with all the research I've done, I can't find enough info on what's better for an RV - vinyl stick planks, or the more traditional sheet.
I have seen a few pics here where the sheet split - I'm in upstate NY, so weather is a big factor to my decision.
But.... how's that vinyl plank for moisture control? Was leaning towards sheet because there are no gaps, but I shudder at the notion of all the work and then a crack after the first winter! I like the idea of the plank/tile installation, as it seems way more familiar to me, having done floating wood floor and the like, but I'm worried with the temp expansion/contractions the gaps will be bigger, and any spills can wreak more havoc.
Also, regardless of type, going on top of particle board sub floor, is there a moisture barrier to put down as well?
Any tips or tricks on either of these would be extremely helpful for our decision!
TIA!
  • Cummins12V98 wrote:
    Glue down "LVT" (luxury vinyl tile) is the way to go. Not floating or snap together. Easy to lift one and replace if damaged. Installed in many DentalClinics over the years. I have it in current DRV.
    Is yours weather controlled, though? Mine will not be. Depending on what temp it is for installation, I could leave the tiniest of gaps between tiles, to accommodate? Maybe wax it, just to fill in those gaps? I don't know, maybe I'm worrying too much about the temp aspect. I'll just be so mad if I don't take it seriously enough, and something happens :/
  • Racer12 wrote:
    I have a 2011 Cedar Creek and we ordered it with 12 inch by 12 inch vinyl tiles. I have had a couple of them replaced due to damage (droping things), other than that no problems and I live in northern Minnesota
    Did you put a vapor or water barrier underneath? And are they glued? The floating floor makes sense for the expansion/contraction issue, but with the thinner tiles, I think glue is all they have...
  • Glue down "LVT" (luxury vinyl tile) is the way to go. Not floating or snap together. Easy to lift one and replace if damaged. Installed in many DentalClinics over the years. I have it in current DRV.
  • Put in Allure from HoD 2 years ago. Not recommended for installation in non-climate controlled environments. Looks the same now. Use the Grip Strip version not the click together. Leave a gap around the edges and cut around anything that goes through the vinyl into the subfloor. Do not screw or nail through the vinyl. The entire floor needs to move as a unit.
    • Skiptomylou's avatar
      Skiptomylou
      This is beautiful!!  Thanks for sharing your photos.   I'm planning now to redo flooring in our 2007 Keystone Everest.
      • way2roll's avatar
        way2roll
        Trailblazer
        You are responding to a post that's 5 years old and the op hasn't been here in years.
  • I wouldn't try to put sheet material down myself. IIRC the mfr puts that down before the base cabinets,etc. are installed, for a reason.
    bumpy
  • I have a 2011 Cedar Creek and we ordered it with 12 inch by 12 inch vinyl tiles. I have had a couple of them replaced due to damage (droping things), other than that no problems and I live in northern Minnesota
  • I just installed vinyl plank flooring in the basement of my house. It looks amazing and has a texture to it. I put a sheet of 6 mil plastic underneath the flooring.
    The flooring I bought is rated for 35 degrees f. I have no idea what would happen to it below those temps, but since you’re in upstate ny, it is something to keep in mind.
  • You can get waterproof vinyl. My thoughts on it are that in the plank, if something cracks, you only have to replace one or two pieces, not the whole thing. That's what we have in most of our rental property.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
