zippyphil's avatar
zippyphil
vinyl wrap
I will bring new life to this topic, with this, can you use a vinyl wrap company to seal the roof? I imagine there would still be prep work but would the vinyl be thick enough and durable enough? I would like to think this (vinyl) would fix many leaks around the vents. My plan would be strip the roof of vents, ac... smooth anything out an then wrapping the roof first then the rest of the RV. Thoughts?
-Phil
  • I can't see how a vinyl wrap would work for what you are wanting to use it for. I think it would get brittle and crack around the "weird" contours of the roof - but hell I don't know. If you're after sealing seems and areas around the vents I would just wash it real good and then apply a generous amount of Dicor sealant in the areas that are troublesome.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,382 PostsLatest Activity: Jul 24, 2025
