chris15005
May 29, 2015Explorer
YamaDooed wrote:
I'm not sure why they needed to run two wires down the wall to the new fan switch. You normally only need to pull one black wire from the new switch to the new fan wire. (with a wall switch my option would be to bypass the new fan pushbutton switch) The 12v + is already at the bottom of the existing light switch and needs to be jumpered to the new fan switch. The 12v- just gets connected in the ceiling.
I'm wanting to bypass the switch with my idea I have a new double on off switch to replace the single one now. So you're saying wire fan as is factory run hot to top of switch and run load wire back to ground on fan?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
