Atlee's avatar
Atlee
Explorer II
Feb 20, 2021
Vortex II fans
Getting a new TT Monday. It, like most TT's comes with a weak, under powered fan that would be hard pressed to blow out a candle.
In other trailers I've purchased, I have a Fantastic fan installed in it's place.
This time I'm thinking of putting in a Vortec II fan myself. I know it's not a Fantastic fan or Maxx air fan, but will the Vortec II move enough air to be worth while?
  • Atlee wrote:
    Not knowing anything, what are PWM's? And how do you install reversing switches?
    Lynnmor wrote:
    I bought the cheaper single speed Vortex fan and added PWMs and reversing switches. Now I have full speed control in both directions without wasting energy like the resistors in the Vortex II.
    Search eBay for PWM, you should be able to find videos to help on YouTube. A Pulse Width Modulator turns the power on and off rapidly, as you adjust the knob the time on varies to adjust the motor speed. A DPDT switch can be used for reversing by swapping the plus and minus.
    It really is simple and cheap to do this.
  • Not knowing anything, what are PWM's? And how do you install reversing switches?
  • wildtoad wrote:
    I have one (The Vortec I) in the kitchen of our MH and yes it does pull a bunch of air. But it is a noisy thing.
    Add a PWM.
  • I have one (The Vortec I) in the kitchen of our MH and yes it does pull a bunch of air. But it is a noisy thing.
  • "will the Vortec II move enough air to be worth while?" You betcha!! If going in the bath, it will vent the black tank quite well if pedal held down!!!
  • I bought the cheaper single speed Vortex fan and added PWMs and reversing switches. Now I have full speed control in both directions without wasting energy like the resistors in the Vortex II.
  • Yes, I just finished installing onr on my new to me TT.
    Since the TT has a rear bath, I added a 12v on/off switch with a piot led for my backup camera
  • Yes it will,the multi speed will give you about all you will need.I was very pleased with my install,much easier than the to install than my Fantastic Fan. It is bit noisier than my Fantastic Fan but it moves a lot of air.
