pjhansman wrote:
I've mounted mine on rubber and wrapped all the lines in foam. Still not at all happy with the noise. I will try the flexible line on the pump discharge....but I think there's a pressure tank in my future as well.
To reduce the noise you have to put the flexible hose on both sides of the pump, not just the discharge side. CW sells the noise reduction kits, but I found it cheaper to get the hoses and fittings and do it myself. I can't dispute the accumulator tank, if they weren't so expensive I would have one to slow the pump cycling. JMO
