vlopddap
Jun 17, 2014Explorer
In my Sportsmen the outlets for TV (antenna + power) are located above a small countertop surface (over a closet), so I'll install a solid wood piece around 4 inch wide that goes from the countertop surface to near the roof. I'm gonna glue piece on wall, screw it to the luan panel and then use metal L-brakets screwed on the countertop surface. I do a quick schema in MS-PAINT...
What do you think about this idea?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
