westend
Jun 17, 2014Explorer
Make the backer board for your mount larger so that it spans two studs. What I did was counterbore the holes needed to attach the articulated mount to the backer board, attach the mount with bolts and nuts securely to the backer board, and then attach the backer board to the wall. I glued it and attached the backer board with screws into the studs. I don't remove it for travel as the arm is rock-steady when folded closed. I have a 32" screen.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
