vlopddap
Jul 10, 2014Explorer
Hi! I wanna share the final result of my LED TV installation. I finally go ahead with the modification of a LCD computer monitor mount to mount it on the countertop surface instead of a true wall-mount. Basically the monitor mount have the same 3-ways adjustments than a true wall-mount bracket, but it's held by the desk surface instead of the wall.
I begin by cutting the large (and VERY thick) "U" shaped clamp bracket... using a handheld grinder with a cutting wheel. After that I drill three holes in the now flat bracket to screw it on the countertop right flush to the wall. The rear two screw are #10 2 inch long screw and they gone through the countertop surface into the solid wood frame structure of the wardrobe. The front screw is a 1-1/2 inch bolt that goes through the countertop surface. Trust me, this is EXTREMELY strong especially for a 8-9 pounds LED TV! The monitor mount come with cable management clips, but the cables are pretty thick so I put some zip-tie too be sure...
I use a premium 3-ways LCD computer monitor desk mount from Monoprice (18$) and the TV is a 19 inch RCA LED TV from Walmart (99$). I also use a Philips media player where I connect one of my 2.5 inch portable 1 TB HDD with 200+ DVD disc image inside.
Only remaining part is to install a small clic strap (like child seat) on the wall to ensure the TV are not moving when travelling.
Here's a few pic, sorry for the actual quality, it's pretty dark inside the RV even with the new LED dome lights!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
