AKRiverRunner
Mar 23, 2014Explorer
That is good to hear that the frame is steel and no structural damage has been done. Most of the damaged wood is in the cabinet above the sofa. I will probably pull off the water logged wood as much as possible and glue a new piece back on. It will be easy to hide inside the cabinets. There are no signs of exterior delamination, but there is one crack above the door corner.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
