Mike_Ehrmantrau
Oct 13, 2015Explorer
shepstone wrote:
Pretty nasty stuff there. You will have to find out if there are studs of any kind in the wall and rebuild from there. I cant tell if the metal piece is a stud or not , you will have to remove some more of the luan to find out for sure. Does the rot go all the way to the outside wall?
Hard to tell. It does appear to be a stud. Would you suggest I peel back more and take more pictures? I was planning to use Abatron's Liquid Wood to harden dry rotten stuff. I have used it in the home before with good success.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
