Thinking of putting a 20 gallon short water heater out side our permanent traveltrailer in florida, it will be in a enclosuresed storage box. this will be an electric heater, is this feasible> the old...
I think it would be very feasible, it's just a matter of running the pipes and wire into the trailer. If you use Pex Tubing and SharkBite Fittings it should be farily simple. Just make sure the Pex is protected from the sun if it's exposed, pipe insulation should be sufficient.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
