ford_coupeExplorerOct 22, 2013water heaterThinking of putting a 20 gallon short water heater out side our permanent traveltrailer in florida, it will be in a enclosuresed storage box. this will be an electric heater, is this feasible> the old...Show More
skipncharExplorerOct 22, 2013Do you have enough fresh water tank capacity to devote so much to hot only. Once you reach 20 gallons you will have zero hot water available.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
