craig7h
May 06, 2024Nomad II
Have you taken the screen off of the pump and cleaned it? Even though you do not winterize there maybe a winterizing value and hose end that is there to pick up the antifreeze out of a jug. That would cause the issue if not in correct position or hose is cut. You did not say if your fresh water tank is full or not.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
