MikeGL's avatar
MikeGL
Water Pump
Hey y'all. We have a 2012 Forest River Shamrock 21SS Hybrid. We do some boondocking and I want to up upgrade the water pump. Can someone tell me what the flow rate is on the factory one, since I cannot seem to find it anywhere and I can't run check as the trailer is in storage. I'm looking at a new one that's 4.5 GPM. But, I don't know how that compares to whats in there now. Thanks, appreciate it.
__________________
  • I can get to it, just not right now, it's in storage and not easily accessible. Just figured someone might know is all. No biggie.
  • Can you get to the existing pump? They're normally marked with their delivery rate. The ones they install at the factory are usually in the 3.X range.
  • I would just like a stronger flow rate is all. I understand water conservation, but there is usually a water tap where we camp that 150 feet of hose will reach if we run out. Absolutely nothing wrong with what we have, just somewhat weak, as I assume it is in all RV's running off a battery or generator.
  • Boondocking? You dont want to pump more water, you want to pump less. Is there a problem with you system now?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 23, 2025
