myredracer
Jun 24, 2015Explorer II
Lynnmor wrote:myredracer wrote:
We are presently at a CG with low pressure, just 20 psi and that's on a good day. I sure wish these regulators could regulate back up to 60...
But Gil, this is a case where you fill your onboard tank and use the water pump.
Yup, you're absolutely right. No sewer hookup here so are minimizing water use anyway and not really bothering us much. Public restroom is next to us which is a help. Looks like we will get a week out of our black tank, shattering our old record by 3-4 days.. :) We're right across from their water tower and I would have thought the pressure would be better than it is.
We have our fancy 3-stage water filter setup which only runs off the city water inlet. Not sure if I want to introduce the CG water into our system, although very likely not an issue at all since we wouldn't drink it anyway. Will likely modify the plumbing somehow one day so that water from the FW tank will circulate through the filters. Since I can't access PEX underneath, I may just set up something so I can connect up a hose outside directly from the pump to the city water inlet.
If water pressure isn't the only issue, the voltage has been down to 105 volts in the evening with nobody running AC units here. Really having to tough it out at this CG. :(
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
