path1's avatar
path1
Water regulator question. 35 or 45 or max PSI?
What do you consider the max your water regulator should be set at?
My old non adjustable water regulator says "max 45" but really only get 33. My shower head works fine and everything seems to be OK. But if I could get a little more pressure the better. Of course I don't want to over do it.
Picked up a Watts yesterday that adjusts and I can set the pressure where I want it.
Wondering what do you run yours at if you have adjustable type?
Thanks
  • I have an adjustable regulator and a pressure gauge. Sometimes when the inlet water is below 60 PSI, you really never get the flow required to take a shower.
    When I test the campground, and IF it is below 45 PSI, I forgo the regulator. Water volume is much better in that case. Yet most campgrounds seem to be well above 60 PSI, and a regulator is a must.
    When I was living in the RV for months, and tired of lack of water flow (the house has 100 PSI) I bought a whole home regulator and garden water hose fittings, to make it work. This gave me a capacity to adjust the regulator, and volume upwards of 10 GPM! However it is not nearly as portable as the small brass ones.
    I have adjusted my Watts adjustable regulator to about 55 PSI output pressure, according to it's gauge. However while taking a shower, the gauge drops to about 40 PSI.
    You don't want to expose the RV plumbing or fresh water hose to more than about 55 PSI, 60 max.
    Have fun camping!
    Fred.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,385 PostsLatest Activity: Aug 08, 2025
