rjniles's avatar
rjniles
Water tank filling mod
A modification I made to more easily fill my fresh water tank. I installed a 1/2" threaded 3 way ball valve in the area of my water pump. I connected the input to the valve to the outside hose connection. One of the output ports I connected back to the water pump, the other output port I connected to the old breather hose to the fresh water tank. I cut a hole in the bulkhead wall of my front storage box to access the valve handle. The old filler hose now acts as the breather hose and I can still fill the tank with that hose.
With a hose connected to the RV, I reach the valve thru the storage box and turn to the fill position. It will fill my tank in 4-5 minutes (will depend on water pressure).
I used PEX pipe with SS cinch rings for the connections(I own the tools and connectors). You could also SS 1'2" FPT faucet connectors.
Trying to figure out how to post a picture.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
