CumminalongExplorerApr 15, 2021Water tanksWanting to extend the water drain outlet so it reaches the edgeof the tank, like to put a tap on it.what can I use? John
SHREDExplorerApr 15, 2021A short pipe with a threaded plug? Is your goal to drain it without water pouring all over the place and instead to the ground?
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
Related ContentWater tank won't fillWater pump?Why no hot water?Grey water tank won't drain completelyNo flow from hot water tank Nautilus P1 system
