CumminalongExplorerApr 15, 2021Water tanksWanting to extend the water drain outlet so it reaches the edgeof the tank, like to put a tap on it.what can I use? John
lwbflExplorerApr 15, 2021Depends on what you have, mine is a 2" pipe with a gate valve coming directly out of the bottom of the fresh water tank.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
Related ContentWater tank won't fillWater pump?Why no hot water?Grey water tank won't drain completelyNo flow from hot water tank Nautilus P1 system
