CumminalongExplorerApr 15, 2021Water tanksWanting to extend the water drain outlet so it reaches the edgeof the tank, like to put a tap on it.what can I use? John
midnightsadieExplorer IIApr 15, 2021use a quarter turn valve and some of the idea,s above, plastic pipe easy to work with.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
Related ContentWater tank won't fillWater pump?Why no hot water?Grey water tank won't drain completelyNo flow from hot water tank Nautilus P1 system
