CumminalongExplorerApr 15, 2021Water tanksWanting to extend the water drain outlet so it reaches the edgeof the tank, like to put a tap on it.what can I use? John
BILDERExplorerApr 16, 2021Extend using pex 90with a shark bite style valve with a hose end, to just behind the bumper, now can fill and drain with out getting under the trailer
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
Related ContentWater tank won't fillWater pump?Why no hot water?Grey water tank won't drain completelyNo flow from hot water tank Nautilus P1 system
