SCVJeff wrote:
If you're going to do it, do it right. THIS is the standard adapter that everyone uses, and also gomes with a smaller hose to tie in an external tank if you ever drain the main tanks. Most important, these have brass caps over the external feed when not in use.
There is another model that doesnt have the external tank hookup as well.
X2. I usee this also. Works great. As for wasting fuel when you disconnect the hose I just turn off the tank and let the fuel burn out of the hose at the end of grilling. Disconnect hose and turn propane bcck on if needed. My splitter stays hooked to the tank at all times.
