jd3520 wrote:
I ordered a low pressure 15' hose and converted my Weber Q to run off the low pressure connection already plumbed on my trailer. I also have a regulator connected hose assembly worked up for it so I can power the Weber with a 20 pound tank. With the ability to use both I find myself hooking the Weber up to the 20# tank most of the time. In fact, I don't know the last time I hooked it up directly to my trailer.
Chuck
I'm in this camp. Connecting with the hose turned out to be more trouble than it's worth. The tripping hazard and limited grill location are to issues you don't have to deal with using an additional tank.
I do understand the OP is now full timing and storage space is a bigger issue. Nevertheless I find myself seldom using the hose because it is not as convenient as I thought it would be.
