ependydad's avatar
ependydad
Weber Q to propane tank
First, I'm not mentally (or ability-wise) prepared to modify the Weber Q to support the lower pressure system from the RV. I'm generally not mechanically inclined and life/death of propane is above my pay grade.
That said, here's what I'm thinking:
1) Get a "Y" coming off of a tank and put it between it and the regulator/autochangeover:
https://www.amazon.com/gp/product/B003JCL816/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A1T1R9Q3ML5YGI
2) Get a hose to go from one side of that "Y", down the bottom of the propane compartment and out to the Weber Q:
https://www.amazon.com/gp/product/B007HG7Q5C/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I read the comments on Amazon and it seems that I'll be able to leave this "Y" permanently connected and only connect the grill when I need to since the "Y" should have a check-valve on either side.
I plan on the side with the Weber always having propane. So, I'm not worried about it being on the auto-changeover.
Thoughts? Comments?
  • So you're going to spend $75-80 so you can use up the propane that fuels your fridge, water heater and stove....:S
    IMO, if you don't want to use the throw-away green bottles, yes, you can buy 100 of them for the $80, then buy a small tank to carry with you that can be refilled at almost every campground.
    How much propane is going to wasted every time you disconnect that 12' hose?:h...Dennis
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Feb 26, 2026
