Bill_Satellite
May 06, 2014Explorer II
To use the H25 receivers you will require a SWM setup. The Carryout portable dome can have the SWM8 hardware added and it will work with your 3 H25's just like they now work with your tripod with the exception that you will not get the HD versions of the available channels (231 Food Network? Yes! 231 Food Network HD? No.)
The SWM8 setup requires a different power inserter than is used by your current tripod antenna so just be sure you keep the 2 systems separate and the correct hardware connected to each.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
