raztec
Jun 15, 2016Explorer II
I was told by Rex, the head guy at Northstar, that's where a lot of people put the second battery.
I was under the assumption that 6 gauge would be ok, but thanks for the heads up.
A 2/0 is awfully thick and will require much bigger holes and not sure how well it can bend around tight corners. Can I get away with smaller?
Also, I presume the batteries would be discharged evenly and should be hooked up in parallel. Any reason to have them swap positions every so often?
Thanks
Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
