DrewE
Jun 16, 2016Explorer III
What sorts of loads do you have on the batteries? If there are no large loads (like a sizable inverter, for example), you'll definitely be fine with such wire, and could probably get away with somewhat smaller. Wire sizing is dependent on the current that will flow.
Do be careful to connect the batteries up in a balanced fashion and to do your best to ensure that the two interconnecting cables are the same length and gauge. Wiring them to be balanced means having the positive connection to the camper's systems at one battery and the ground connection at the opposite battery, so that current to or from either battery will travel through exactly one of the two interconnecting leads before getting to the rest of the world.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
