coolmom42's avatar
coolmom42
Explorer II
Dec 12, 2020
what material would work for this?
I want to construct a faux headboard to block off the window above the bed in my RV. (It's not an emergency access window, there is another window near the bed, and this window is annoying.) I'm going to nail or screw the faux headboard to the wall, so that it bridges the window, and blocks it. I'll cover it with some type of fabric, not sure what yet.
I want this to be rigid enough to lean back against. The window is slightly recessed, maybe 1/2", so the headboard needs to be rigid enough to support itself and me when I lean on it (with a pillow, probably.) But I need it to be lightweight enough that I can fasten it to the wall with fairly small/short screws or nails.
The finished size will be about 36" tall and 48" inches wide.
My first thought is 1/2" plywood but I would definitely like to have something lighter. What material would be lighter but yet rigid enough? 1/4" plywood would be light, but I'm not sure it would be rigid enough.
Also, what is the most reliable way to find the wall studs to support this (or anything else)?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,390 PostsLatest Activity: Sep 14, 2025
