Ljava's avatar
Ljava
Wheel bearing repacking
How often do you repack the RV wheel bearings? I'm getting many different opinions on this question.
    • BarabooBob's avatar
      BarabooBob
      Explorer III
      I repack my bearings every fall before I park the TT.  I also carry my IR thermometer and check my hub temps every morning after about 50 miles of travel.   If I have a warm bearing, I can repack it right away.  It would not take me very long to strip t down and repo it.  I do carry a pretty good tool kit, jack, and stand.  I have never had to do it on the road.
      We put 3000 to 10000 miles on annually.
      • PopUpTom's avatar
        PopUpTom
        I also check my hubs with an IR thermometer.  For me it's more for post brake adjustment checks than hot bearings.  I would think that an unexpected hot hub reading (not brake adjustment related) would be a bigger issue than just needing fresh grease.
        In my experience, a hot hub showed up after greasing a bearing - castle nut was too tight.  From now on, I have a center punch mark at 12 o'clock on all my castle nuts, to reinstall the castle nut in the same position/rotation as before the re-pack process.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,414 PostsLatest Activity: Jul 29, 2026
