DrewE
Mar 04, 2018Explorer III
#2 will have less loss because the connection through the long wire is at a lower current level (and higher voltage), so the ohmic loss in the wire will be lower. It's the same basic reason that the power lines on the poles to a house are usually operating at 7500 volts or so, rather than 240 volts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
