westend
Mar 05, 2018Explorer
If you are considering an MPPT controller, there is better efficiency by using a larger, nominal 24V solar panel, than 2 X 100W panels. For the smaller, nominal 12V panels, you won't gain much buying a more expensive MPPT charge controller. Nominal 24V panels typically operate at 36V or so. To get the most out of the harvest, an MPPT charge controller is warranted.
FWIW, I have a 235W panel and a Morningstar MPPT-15 charge controller. It harvests 15 amps on a bright, sunny day when the batteries are not full.
Charge controllers are more efficient when mounted as close to the batteries as possible.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
