Almot
Mar 09, 2018Explorer III
24V panels are cheaper per watt than 12V, but shipping is costly. People normally pick up 24V at the closest warehouse.
Though I couldn't figure out what Westend said about 24V panel being more efficient (with MPPT) than 2*12V.
Panels that OP is considering, 2*100W, have ~38Vmp in series.
Single 200W panel at 24V is a rarity, a common size is 230W and higher. 230-240W panel would have Voc ~37V, but in MPPT it's Vmp that counts, typically ~31V.
20% more wattage (of 240W panel) will eventually result in more solar harvest, but this is not because of different efficiency of MPPT at 31V vs 38V. Wattage is the king :)
Single 24V is easier to install on the roof than 2*100W, but in a portable this will be more pain yet than 2*100W. You don't want to handle 5x3ft sheet that weighs 40 lbs.
2*100W is not something that I would want to handle, either. But I'm mostly parked in the open, so my panels are on the roof.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
