lawrosa wrote:
Just looked up the eco worthy. Looks pretty good and only $99 bucks..
I have to look at specs but I would assume again that it would be best to couple it with a 24 volt panel.
What I read is the mppt controller would double the amps of the 24 volt panel? So that 8.7 amps that 240 panel produces would be around 16-17 amps.
Maybe I would put on the roof of the RV, but I wonder the performance when in the shade....
Probably my load per hour is about 5 amps. TV and a fan. Water pumps use, ect.
I was thinking of doing an invertor to the RV panel somehow.
Its probably wrong to backfeed the panel, and have the main breaker off... huh?
http://www.amazon.com/ECO-WORTHY-Charge-Controller-Regulator-15-30/dp/B00FF1KGT4
A 240w panel should easily do 16a while tracking. The Eco-W can do a 24v panel or a pair of 12v panels in series up to 275w. Pay attention to the specs of the panel and the limits of the controller.
For the hassle a portable allows you to park in the shade and collect more than if the panel was mounted. Solar in the shade isn't such a good idea.
I plug my shore cord into the inverter. the converter is never on but the rest of the outlets are live.
There are a few of us that have used the 24v panel/Eco-W as portables and mounted. I may have used it longer but for day to day experience BFL has much more than I do. I also think he does more with the combo than I did when I ran a single panel system as in use a inverter.
What that 230w panel, 25 ft of cords and Eco-worthy did do for us was produce more power than we could use. Even though it could produce 15a or more tracking the sun, the system was in float most of the time because we don't use enough power over night to pull down the battery much. We could turn on all the lights, fans and even the furnace the system would cover it so the battery stayed in float all day. I've taken the concept of running stuff directly off of the system that the one I use now will run a small air conditioner or cook on a electric cooktop.
Portables, especially big ones have downsides too. Not only do you have to store it for transport but you have to pull it out to use the rig if you just stop for the night. You get no charging while on the road or if the trailer is stored and of course anything not nailed down can grow legs and walk away.
