pianotuna
Dec 06, 2013Nomad III
Hi profdant,
Canvas or space cloth tarps might be velcroed in place around the bottom as a skirt. Heat will radiate through the bottom--and if you can keep the wind away a mini environment would ensue.
Add a hydronic heater powered by the gas water heater with a circulating pump a la smkettner for a heat source.
*Presto* no co risk at all.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
