ohiopicker's avatar
ohiopicker
Will it fit thru the door?
We want to remove the fold-out hide-a-bed sofa from our fifth wheel and replace it with a smaller unit. We know those fold-out's are heavy as all get out, but will they fit thru the door?
I welcome any advice from folks who have done this.
  • Mine fit through with no problem. I now have a recliner and looking for a second one to match.
    BTW. If putting in a recliner, get a wall hugger.
  • the sleeper sofa in our TT, the back came off and it was easy to get out, look for a smaller one that the back comes off also. JMHO
    also it was screwed to the floor with "L" brackets
  • Be sure and tie it together after you get it loose and folded. Otherwise you might be in for a big problem about half-way out the door.
  • Just put sofa in the open/flat position and you should be fine. Stand on edge and it should fit through the door.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
