BKing49
Jun 02, 2014Explorer
Winnebago Class A Roof Construction
Does anyone know how the roof/ceiling of a Winnebago Brave (older - '95) is constructed? I believe that the actual roof is a sandwiched laun/Styrofoam/laun assembly, but not sure. I think that because when I drilled a hole in it for a screw, the drill popped through after only about an eight of an inch. Meaning the screw is into the Styrofoam.
I need to run a cable above the ceiling and below the roof and want to make sure there is a "void" in which the cable can be ran.
Since the roof will hold my full weight with little sign of deflection, there must be some kind of truss arrangement supporting the roof panel allowing for a ceiling panel to be attached to the bottom of the truss.
Is this correct?
Bruce
Is this correct?
Bruce
