doughere
Jul 08, 2015Explorer
You should mount the solar controller as close to the battery as possible. Wire from the panels to controller would probably need to be #10 minimum (assuming that its 20 feet from entrance to RV to batteries, and guessing 20 feet up pipe and to panels). For a 2 ft run from controller to battery #10 is OK.
Doug
Doug
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
