ScottG
Mar 04, 2015Nomad
WyoTraveler wrote:ScottG wrote:
The pump has a check valve so water cannot flow backwards through it and fill the tank when your connected to city water. So I don't think that will be a problem.
That is if I understand your question, which I'm not sure I do. :)
I think he is saying the kink is between the pump and water tank.
That's what I thought and then I wasn't sure.
If that is indeed the case only the water in that immediate line will want to come out.
Just grab a thick towel and sop up any water that comes out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
